mendo069
- 0
- 6
- hesperia,ca.
i was draining all fluids from my beloved deuce when i came across something that everyone fears most...... metal chunks on the transfer case magnet... after draining all the gear oil i fished out even more bits that matched that on the magnet.. my digital camera has taken a dump so i can't post pix yet.. but to me they resemble a bearing cage.. it has a concave piece then a spacer then a concave piece then a spacer... i can't think of anything else it could be.. no bearings were in the oil.. norman at ant. valley eqpmt. said he has never seen this before. first, if anyone might have a clue on what this might be, i can use your input... then, should i replace with a used take out, a government rebuild, or should i shop around for someone to rebuild??? i have heard pros and cons on all of the above.. can get gov. rebuild for about $1000.00 or a used take out for $500.00... then some people say to just run it... i have no noises (bad), truck shifts fine... do you guys think i got time, or should i start on this asap... thanks for your help... mendo.
