Transfer case non-air shift to air shift?
desertfox
Aztec, NM 87410
I have TM 9-2320-361-24-1. I have an M109A3 with non air shift transfer. Would like to change to air shift. My question is are the internals of the transfer cases the same and do I only need to add the front axle engagement air cylinder mechanism to make the conversion. Other than the dash attachments and lines, etc.
Thanks, G
gringeltaube
Staff Member
2,389
Montevideo/Uruguay
Yes, many of us have been there… frying our little grey cells trying to find a practical and cheap solution for that conversion: NO way!:(
Lots of info available, even conversion kits (REB KIT) had been around for some time.
Take a look here if you like: http://shortlinks.net/zpj630
G.
desertfox
Aztec, NM 87410
Ok, thanks guys.
I read the link and changing the entire unit appears the easiest choice. Fortunately I have a parts truck with an air shift transfer.
Again, thanks for the help.
