red devils dude
- 3
- 0
- Ft Campbell
well yesterday I went to change the oil in my T-case took me a while too find the drain and
fill plug's but I did so get the drain pan set and and pull the plug and out comes maybe one
quart of oil I'm thinking O crap the T-case is shot!! well I get on with the job flush
the gunk out of the bottom of the t-case then go to remove the fill plug the 1/2" ratchet cant
move it get the swivel end get the plug out ok now I'm thinking maybe the DRMO drained the oil because the whole T-case has a coating of oily goo and the drain plug was only finger tight but is it normal for them too drain just one fluid??
