TRANSFER CASE POPPING OUT OF LOW
Inspector 1
73
Spring Texas
I have a 700R4 transmission installed in my HMMWV. Since purchase of vehicle about 1 year ago, transfer case has always popped out of low. I have to physically hold shift lever down to drive in Low. I have no problem in HL or H. Any suggestions?
Ajax MD
1,414
Mayo, MD
Low range is at the rear of the slot. Are you actually hitting the edge of the slot with the shift lever?
If so, get under the vehicle and adjust the throw of the shift lever to give you a little more throw. Perhaps you're not fully engaging the low-range.
Inspector 1
73
Spring Texas
I seem to have a little room left before the shift handle hits the edge of the slot. I will say that it just doesn't feel like a solid lock when shifting in low. Thanks for your advice.
