- 34,012
- 1,807
- 113
- GA Mountains
Morning gang. I've got the PTO on the back of the old M756A2 transfer case. The truck was very rusty and subsequently some items on the PTO are rusted as well. The output shaft turns easily but the shift rod doesn't move. Liberal use of penetrating oil and some heat should rectify this. The gear was removed so it has a tapered output shaft with a keyway. I have the oil tube and fittings but the oil tube itself shows scaling rust. I also have the data plate for the cab and the shift rod that goes across the floor behind the seat. The only piece I don't have it the link between the shift rod and the PTO, it fell apart upon removal. Should be easy to fabricate. I'll have this removed and pics posted by days end. These PTOs are usually a big ticket item but this one is available for $250. If no interest in a day or two, I'll put it on Ebay.
