Transfer case shift question
porkysplace
1,494
mid- michigan
I figure I'd ask before any reasonable amount of snow comes, can our transfer case be switched into lock while moving?
Mike
Welcome to SS and Merry Christmas. Here is a link to the -10 operators TM and screenshots of proper transfer case operation.
It would be a good idea to download and read this manual since your new to HMMWV's .
TM-9-2320-280-10.pdf
TM-9-2320-280-10 Operators manual for the M998 series truck. June 1991.
TM's for the M998 series
warcow105
Lincoln Park, NJ
Thanks, and I'm definitely going to read through... But we all know proper procedure might not be the only procedure :)
I'm only wondering because I had a 77 k5 with a part time conversion, and during the winter I would keep the hubs locked and switch into 4wd as I was coming up to hills or potentially slippery stops while moving.
Mike
Milcommoguy
2,384
Rosamond, CA
Beat me to it Porkysplace... Here it is again,The free owners manual, TM-9-2320-280-10.pdf
CAUTION• Vehicle must be stopped, engine off, and transmission shift leverplaced in “N” (Neutral), before transfer case can be shifted.Failure to do this will result in damage to drivetrain.• Do not place transfer case shift lever in “H/L” (high lock range) or“L” (low range) on high traction surfaces where little or no wheelslippage is evident, particularly when encountering sharp,continuous turns. Failure to operate the vehicle with transfer casein “H” (high range) on high traction surfaces, particularly whenencountering sharp, continuous turns, can damage drivetrain.b. With transmission shift lever (2) in “N” (neutral), select “H” (high range)transfer case driving gear range using transfer case shift lever (3). This range isfor normal driving in good weather, or on high traction surfaces.c. Start engine (para. 2-10).d. Set vehicle light switch (7) (para. 2-13).
You might get away with making a shift, but more that likely will grind till the instructions are followed. To get it to shift in or disengage, may have to roll in reverse then forward a few feet.
Results may very,
CAMO
warcow105
Lincoln Park, NJ
Hmm, just went out and had a look. I never realized how much rotation was carried through an automatic in neutral. Now I definitely need to convert over to a trans with park, I don't want to deal with turning off the engine just to shift the transfer case.
Mike
porkysplace
1,494
mid- michigan
Mike
Military vehicles have a lot of differences from civy models , and can get expensive when the right order of things isn't followed , particularly with start-up and shut down procedures.
warcow105
Lincoln Park, NJ
The later models with the 4 speed and park operate the same as any other truck with shifting the transfer case, it's just the lack of a parking pawl on this 3 speed that's the issue. Nothing else has caused me confusion so far.
Mike
papakb
1,196
San Jose, Ca
Read my posting on adding Park to a 3 speed here: https://forums.g503.com/viewtopic.php?f=63&t=263221
Any average mechanic can do it at home without pulling the trans. The most difficult part of the entire job is finding the shifter.
Augi
42
SF Bay Area
Shifting the 218 is different than shifting the 242.
For the 218 the above is correct.
The 242 can be shifted between H and HL on the move at any time.
I have found with my 242 that for shifting from H to LL to be guaranteed successful the tuck must be rolling 2-5 mph with the trans in neutral. If the truck is stopped 50/50 the t case will get stuck in neutral and grind instead of going into LL.
Augi
sue
375
tulsa OK
Like Dave said, H to Hloc on the fly with either
transfer case, no problem. Hloc to H on the fly
might have some bind so be aware.
