Transfer case shifting and BTM
thoner7
162
NE TN
Went off road for the first time recently. I had some trouble shifting the T case. It would grind gears when trying to shift. Park (for the trans) seemed to work for shifting into HL but not always. I took a video
but the only time I got it into L was with the trans in N. Except for my third attempt in the video
I let the truck roll to take and pressure of the drive line etc. what am I missing?
Also for the BTM - I struggled to get it to engage. If I remember what I read - 1800 rpm and light pressure on the brakes? It’s hard to have light pressure on the brakes when you are half way up a hill! I never even got the truck to 1800 rpm in that instance.
I did get it to engage the one time I had the T case in L, but had no luck the other times. Does the Tranfser case have to be in low range for the BTM technique to work?
REF
Porterville Calif
CAUTION
• Vehicle must be stopped, engine off, and transmission shift lever
placed in “N” (Neutral), before transfer case can be shifted.
Failure to do this will result in damage to drivetrain.
• Do not place transfer case shift lever in “H/L” (high lock range) or
“L” (low range) on high traction surfaces where little or no wheel
slippage is evident, particularly when encountering sharp,
continuous turns. Failure to operate the vehicle with transfer case
in “H” (high range) on high traction surfaces, particularly when
encountering sharp, continuous turns, can damage drivetrain.
From TM9-2320-280-10 section 2-108
hope this helps
thoner7
162
NE TN
Wow - truck off!? That’s surprising. Better not need to shift in a hurry lol.
What about BTM? How high do you keep rpm’s? My truck only went to about 1500 rpm with my foot on the brake.
Once the diffs lock, and you start moving - do you let off the brake? does the Diff stay locked if you do?
Coug
4,241
Olympia/WA
When I'm doing it, I usually bring the RPMS up a bit, then loosen up a little on the brakes. As long as you have light pressure on the brakes, it should stay locked up. You're doing more modulating of the brakes than you are the throttle most of the time.
You do have to keep light pressure or the diffs will unlock.
frauhansen
538
switzerland
Sorry, but I didn't understand that. Is this a joke that I, as a foreign speaker, don't get? Or does this manual really exist? Is it some kind of crash course or HMMWV for dummies? Tryed to google it, but no relevant results.
frauhansen
538
switzerland
Ahhh, that's it. Thought you meant a different one.
I had already studied this, and others, during the long wait until my truck arrived.
It is extensive, yes. And it affects a lot of models. And I would have cut it down to half if necessary. But why is this " dreaded "?
Coug
4,241
Olympia/WA
the dreaded part was sarcasm, as many people seem to dislike the idea of having to read and finding what they need to know from a manual, when they think it is easier to just ask questions (the same ones that get asked over and over, taking up a lot of forum pages)
Milcommoguy
2,167
Rosamond, CA
It's NO joke. Human kind is loosing it's mind / memory. Is it just us old farts with HumV's ?? OR is it just all the good librarian's have been put out of work due to a google, an app, a forum? I'am not sure BUT I see it over and over here.
Not saying it is not OK to ask. If one doesn't know jump in here and ask away. We are born with "why and how" MOGMAN, full time ask Daddy (y)(y)(y)
The TM's and a bathroom are a good place to start, LOL. Get your business done, info learned or even gleaned.... Now in memory all the other senses reinforce it, eyes, hands, ear's, even smell, the whole spectrum add up when cawing thru the problem HumV". Memory retention improved and no batteries required. Mommy....Where's the spray...Daddy has been studying again, LOL :poop:
A thumb drive is flipping thru the TM, CAMO
frauhansen
538
switzerland
To be honest, if I hadn't read the manual, I would have handled it in exactly the same way as all the other transfer cases. Especially when I know it's an (NP)242 like everything else I've driven on Jeep, Durango, RAM.
So the idea of operating the car as it appears to you is obvious and is no reason to lose faith in the world ;-)
Mainsail
1,583
Puget Sound, WA
CAUTION
hope this helps
Except:
I can attest that my M1165 T/C does NOT shift unless the engine is off.
thoner7
162
NE TN
I’m sorry if I missed the truck needing to be off in the TMs. I had tried N and P and assumed something make be broken as some of the shift linkage seemed to bind up at times.
I searched through the TM for the BTM instructions and have come up empty. Searching the document for the terms: brake throttle, brake-throttle, modulation, differential, all come up empty. That’s a common issue I’ve had with the TMs - not know what the military calls things. I’d search for switxh but the military calls it a toggle. Search for washer and the military calls it a disk spacer or something strange.
Retiredwarhorses
4,122
Brentwood, Calif
BTM is not in the TM’s, this was taught during driver training…FYI, in the military, no one could operate any piece of rolling stock without having
been certified by a trainer, only than could the piece of equipment be added to the soldier, marine or Airman’s military Drivers License.
IIRC, the BTM portion was part of a more extensive training course for self recovery…
