bugei
- 3
- 18
- reno nevada
i need a transfer case wizard to explain the cause of a problem i am having. i just toasted a SECOND bronze high low shift assembly. the symptom is the truck will not go into high range, and i am pretty sure when i take it apart, i will find that the bronze ring will have "shrunk" on the shaft and will not go into high range.
the oiler seemd ok when we put it back together, what did we miss? since this is a wrecker, it needs to be able to run with the transfer case in neutral without killing the transfer case.
thanx in advance
thanx in advance
