- 26,246
- 1,176
- 113
- NY
Does the transfercase,(M35A2) have a neutral position? ( All I've seen in manuals is High or Low position)I'm trying to figure out if I need to remove the driveshafts to tow the truck home. I may flat tow or I might lift the front to tow with a wrecker.(wrecker guy said to remove both front and rear shafts before he will tow it) This truck appears to be an air shift front end. Does the air pressure need to be up to disengage the front axel or to shift the transfercase?
