Transmission and sprag t case
tie6044
42
Blaine, MN
Looks like your are new to the site so be ready for the search police. If you have a sprag t-case then you need that rod and arm, if you have an air shift case you can remove the arm but the rod stays. It tells the sprag t-case which way the truck is going in case it needs to kick in.
