I was crawling around under the Deuce today doing some PM, and discovered a bolt hole with no bolt on the rear of my transmission. The bolt hole is just to the left of the countershaft rear bearing cover, but it does not appear to be one of the cover bolts.
It appears to be a 3/8" fine thread (the cover bolts are 3/8" coarse thread). I poked a smaller diameter bolt in the hole, it went in about 1" and hit a hard stop but I couldn't get close enough to see if it was a blind hole or not.
There does not appear to be any trans oil leaking out this hole, but the threads were clean and shiney with no crud on them at all, as though the bolt had just been removed.
I'm clueless and the transmission TM doesn't give enough detail of this area to be of any help. Does anyone know what goes in this bolt hole or should I just put a short bolt in there and let it be? BTW, this is an English built 3053 tranny, NOT a 3053A.
