2deuce
- 147
- 63
- portland, oregon
Has anyone used an AC radiator as a trans cooler? It would be a really large cooler. Can you cool too much? If one of these was used should it be turned off in winter or when your not towing? How much pressure does the transmission pump thru the stock cooler lines? I saw that the lines are a different size. I thought I'd use rubber tubing to do the connection, then fasten the cooler to the radiator like the aftermarket coolers, and put a valve in the line if it should be turned off in cold weather. Would it be better to put it after the radiator or bypass the radiator altogether.I'm for saving a few $ if this will work. I have the ac cooler I pulled off another truck long ago. Thanks
