Transmission drain/fill plug
187
Youngstown, OH
The plug located at the bend in the transfer case shifter is the incorrect plug, right? The correct one is located lower near the T-case linkage?
brianp454
11
Portland, OR
I know what is in the TM's, yet it seems that doesn't correspond to the fill plug. I was always taught to fill to a little under the fill plug. My transmission definitely had more than what is called out in the TM. I drained my transfer case and transmission, will fill them later this week. Can anyone confirm what is the correct fill level and why?
Drained and filled the differentials and the transmission/transfer case. Some nasty stuff came out. All good now :)
Whiterabbit
14
Bristol Va.
I always fill till it starts dribbling out the fill plug. There's a reason the engineers/designers put the fill plug at that specific spot.
True, some manuals say fill just to below the hole with some big truck's diffs but I've never had any problems with filling my trucks to the hole.
nattieleather
140
Cleveland, OH
I use to drain the trans and the pull the fill plug and the gear shifter. Then filled from the top till it ran out the fill plug hole. Much easier than trying to tip a bottle up into the fill hole with the trans mounted in the vehicle.
armytruck63
10
Redlands, CA
I like the using the gear oil in either one or five gallon containers with the hand pump. That way, you don't have to try to lift a little bottle up to the fill hole, just the end of a hose.
