Leaky G749 transmissions
I sent a seal kit down to Rustystud so if he's opened it, he might be able to tell you if that seal is part of the kit...and what size it is. It might even be this one but I can't see a part number on it so we still have some info to gather.
Turning to this page, we see 2 Ordnance Stock no.s. 7411666 and 8333405......and I'm not sure why.
Manufacturers part #'s MFRS Part no.s are 8613649 and 8615499.........respective. Those numbers don't search well to find 'crossover' parts.... but I did see a bunch of groovy high tech patents searching "seal" , then the number.
The seal is described as SEAL oil, reduction unit output shaft, assy ( 2 1/2 x 3.626 x 3/4 )
or
( 2 1/2 x 3.626 x 5/8 )
This is a problem. They both say they supersede part 666 so ........did they change the shaft size at some point......What am I missing? Is the 3/4 or 5/8 a 'width' measurement?
There are a couple of guys around that rebuilt these before. If they don't chime in soon I'll knock on their door and we'll try to figure this out.
I've looked through 301MG and 303M Hydromatic transmission manual 9-8025-2 to check OD on the shaft but it evades me.
At the top of the Early Deuce forum you'll find a pile of Technical Manuals, TM's ....USMC 00-08 has put together a spectacular "Current available parts list", a few stickies with some good info...all for your reading pleasure.
Meanwhile, until we get a solid answer, here's the timken seal pdf,
http://www.allsealsinc.com/pdfs/Timken_Seal_Interchange_and_Cross_Reference_Guide.pdf
