Transmission pukes oil from input.
shannondeese
High Springs Fl
I have a problem with my transmission. When I fill it up to the rim of the fill port, for the next few hundred miles it pukes 90wt when I stop. It all drains out of the hole in the clutch cover. It leaks until it's about 1 to 1 1/2 inches below the fill port. It has been doing this for about a two years. Is there any way to get it to stop or is it ok to let it run a little low. Thanks.
1,176
Pull the trans and look it over. Your front cover may be loose or missing bolts.
Obviously after 2 years, it is not going to heal itself.
4,744
Common problem, search will return a lot of info. The fix typically is a new input shaft cover. It's a close fit that helps seal it in. Check your vents as well on the transmission. Some have also reduced the oil level in the trans to aid in the problem. But typically the fix involves removal.
pigfoot63
Gainesville, Ga.
X2 with PA, I have repaired many of these. The front input cover will wear usually because your pilot bushing is worn out. Also the expansion plug in the front of trans will leak, the vent in the trans can be defective and yes your trans can be overfilled.
73m819
319
gainesville, ga.
Fill to about a bit under one knuckle down, this WILL stop your leak,
1,176
Not if the bolts on the front cover are loose or missing.
4,744
Agree with both statements. If the bolts are good and tight, a knuckle low will "cure" a slack input housing. Loose/missing bolts, nothing will change.
