transmission questions
MuleMac01
Military vehicle collector
158
Las Vegas Nevada
I tryed to serch this but no luck if the transmission fuild is a little high on the dip stick would the TH400 shift at higher rpms? If so how would be a good way to take a little out. I hope i dont half to break the gasket to do it.
raiburn
Fort Wayne, Indiana
Fluid comes out when you remove the Vacuum Modulator. It is only one rubber hose, and one bolt. It is located on the passenger side of the tranny, pointing out sideways.
MuleMac01
158
Las Vegas Nevada
ok got the fuild down to a good level now when hot test drove on the freeway wants to shift to secound about 25-30mph fells like the engine is going to blow lol maybe i should start buying new hose's and a new vac mod
