transmission temp high
tubamlb
Delray Beach Fl
Hi
The 936A2 Transmission gauge shows that the transmission is overheating , The radiator is cool but the heat ex changer is hot ?
any ideas ?
Thank you
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
What is the temp on the heat exchanger? Did you use a temp gun to verify temp ? Do not always trust the gauges. You need to determine what the temp is in the lines, exchanger, the air cooler in the grille and the pan.
The exchanger should be hot since the engine temp of 180 degrees is attempting to cool it. Just verify the temps with a in-fared gun and report back.
Floridianson
2,491
Interlachen Fl.
Agreed check with IR been there with gage problem. If the gage is correct can I ask what are you doing when it shows running hot. In town traffic stop and go, off road or highway.
