Transmission upgrade?
2Deuces wild
calif
Hi guys, I have a question. I have a 13 speed fuller eaton roadranger rto 14613 transmission .
will it fit in my 68? Thanks Kalen.:grin:
fasttruck
633
Mesa, AZ
Anything can be made to fit into anything else if you throw enough money at it. Problem with transmission swaps in m35s and 809 vehicles is trans it linked to tranfser case with either a rod linkage or air control so trans orients t case as to direction of vehicle travel. if you change the trans you will probably loose the fwd capability too.
Nonotagain
41
Parkville, MD
I think you need a bellhousinig from a 5 ton as the M35 uses a small bolt pattern verses the large bolt pattern of the Fuller transmission.
Unless your transmission has overdrive for 11-13 speed, the only thing you gain is a tighter ratio between gears.
BFR
Rocket Surgeon
2,330
42
North Georgia
If the duece has an airshift tcase, changing the trans will not affect fwd operation.
The big question is how long is the fuller trans?
m16ty
211
Dickson,TN
I've got a spare RT613 and I've looked at other Roadranger trasmissions. The main problem I've seen is any trans with a range split is going to be quite a bit longer than the stock trans. To make room for the longer trans you're going to have to move the t-case back. When you do that you start running into driveline angle problems between the t-case and foward rear axle. If you go off road much the rear axles move a bunch and you run into some pretty sharp driveline angles even in stock form. I think if you move the t-case back very much off road capablity is going to suffer.
m16ty
211
Dickson,TN
One more thing, A RTO 14613 is a BIG trans.
R- Roadranger
T- twin countershaft
O- overdrive
14- max tourqe 1,400 ft. lbs.
6- application number
13- number of speeds
Chevytruck
Western Maine
getting a faster transmission might not always be a good idea, because then you would be over driving your brakes, and putting a whole Lotta more wear and tear on the drive train.
Remember these were designed for a convoy speed of 45mph.
just my 2 cents
m16ty
211
Dickson,TN
I don't know how much overdrive the trans in question has but I bet you wouldn't gain much speed if any. What you would gain is closer gears which would be better for pulling a load.
The stock trans has a heck of a jump between 3rd and 4th. From what I understand the 3053 came about by modifing a 3052 instead of building a whole new trans from scratch. They fit the overdrive gear into the 4th gear spot so basicly the 3053 is missing a gear. That's the reason for the big jump between 3rd and 4th and the funky shift patern.
tm america
24
merrillville in
whats the shift pattern on a 3052. if what m16ty is saying is correct i would be able to pull heavier loads with a 3052 im my deuce but it would knock my top speed down to probably about 63-65 with the 15.5s:roll:maybe its time for me to start looking for a gasser trans:-D
m16ty
211
Dickson,TN
The steps are alot better spaced on a 3052 but no OD. The shift pattern on a 3052 is a standard "H" pattern.
