transmissions
moparguy4x4
chesapeake,ohio
I have a 55 reo gasser trans and was wondering if the first gear was lower than the od multi fuel trannys i got the off road duece and would like a little lower first gear and was wondering if trannys would interchange and if they didnt would the pto of the non od work on the od tranny thanks
Stretch44875
Super Jr. Moderator
29
Tiro, Ohio
I don't know the numbers, but the gasser tranny has a lower first gear. PTO will bolt up fine. For off road it would be nice, the gears are spaced better without the overdrive. Same transmission, different gearsets, will interchange.
Dennis
gringeltaube
Staff Member
2,389
Montevideo/Uruguay
3052 vs 3053A, gear ratios
Actual numbers, for comparison:
Spicer 3052, 5th direct: 7.552, 4.182, 2.446, 1.455, 1.000, R 7.364
Spicer 3053A, 5th o.d. : 5.013, 2.776, 1.624, 1.000, 0.787, R 4.888
PTO is the same for both but output rpm is only 0.66%, mounted on a 3052 (if 3053 was 100%).
G.
