- 3,206
- 3,201
- 113
- NORTH (Canada)
Troop seats - stuck piece of wood **solution**
(for update, see below)
I have one piece of old, wooden cargo bow upright stuck in the troop seat square pipe. Soldier A had left it there and the wood got wet, swelled up and got stuck. Eventually, someone broke the upright off. I need to remove it, so I can put a new cargo bow in. Can't be that hard to get out, can it?
Ok, so I drilled out what I could with a long drill, then got a longer drill. Drilled several holes right trough the length of the piece, top to bottom. Scraped out wood as deep as I could reach with long drill. Have about 6-8 inches in the middle I cannot get out.
Cannot scrape out the wood in the middle, because the flex drill that is long enough to drill through always slips into one of the already drilled-though holes.
I used a blow torch to heat up the square pipe and tried to ignite the wood inside as well.
I had noticed that the sawdust I got while drilling was soaking wet (despite the truck not having seen rain in almost 6 months), so I was not surprised when I could not ignite the wood.
After the heat treatment I thought I felt a little movement, so I grabbed a piece of fiberglass stake which fits the squre pipe very snugly and used it to whack out the piece of wood stuck in the middle of the troop seat pipe.
Seemed like a good idea at the time. Wood did not budge. Now I have a fiberglass stake stuck in the troop seat, as well as the rest of the rotten wooden cargo bow upright. I guess there are splinters of wood sticking out that wedged themselves between the fiberglass and the inside of the pipe, firmly locking it in.
Tried all sorts of things to get the fiberglass stake back out. No dice. Doesn't budge. Used the flex drill and drilled holes right alongside the fiberglass.
Whacked the thing in the vice in various ways as if there was no tomorrow. Nothing.
My next impulse involved a gallon of gasoline, so I stopped before I could dig myself an even bigger hole and parked the truck for the night.
I am not feeling particularly intelligent right now and welcome suggestions!
***** UPDATE*****
"Punching through" with a rod did not loosen it up enough to get the plug out.
What worked: One hour on the propane barbecue, full blast. Let cool, then use steel rod to easily knock the now charcoal-like wood out. The fiberglass piece transformed into blackened strands of fibers.
Clean, prime, paint the upright.
I recommend burning the wood out of the upright.
***** UPDATE*****
