Y2815
- 0
- 0
- Parker, CO
Have a M1009 with the 6.2L - last week it was very hard to start (acted like it was not getting full) after some time got it to start, then the Idle started to get strange. Sitting with no pressure on the peddle, it would rev up and then get super slow to the point of not wanting to run. I could go in and manually rev it up and get it going again, would run normal for a short time and go through the same thing....sometimes fast and others very slow. It does not seem to be a consistent issue, just on an off...my though is I have a Injector Pump that is getting ready to crap out or an injector that is bad. It appears the IP is a bit costly and time consuming to replace and the injections are far less and a bit easier to fix. I wanted to get the thoughts of the more experienced to see if you think it is the pump or injectors.
Assuming one or both of the above are the case, where would you suggest I get the replacement parts?
Thank you,
TJ
Thank you,
TJ
