Truck delivery in Va./Md./WV./Pa. areas
I used a trucking co. that is located in Shippensburg, Pa. which is about 10 mile from the Chambersburg,Pa. site and about 30 mile from the Mechanicsburg, Pa. site.
They also do have traffic that does get them in the Balt. Md. area and down into the Norfolk, Va. area.
They have flatbed, stepdeck, and detach lowboy trailers, would need a dock or an easy to get to dirt bank to back in to to unload a flat or step deck there would be extra charge for the detach lowboy (speical equpt.)
As much planning at pick up that you can do to get them in and out fast would help(make sure there would be dock you can use, if the truck won't start will equpt. be avalable to push up an trl., If you could be at pick up to help keep things going.)
One advantage of hauling is no wheels on the ground is less to worry about(flat or blown tires, smoking a wheel bearing all could be a problem even on a hook.
Can't really say what cost would be, I got a speical rate becouse I used to drive for them and know the V.P. of Operations so was like calling old friend.
I can give you there number if you would want or pm me.
