- 5,580
- 349
- 83
- DESOTO, KANSAS
Ok do you guys with M109's or shelters use the grounding lug and run a wire to earth when you plug into shore power. The reason I ask is I just finished rewiring my box from 60 amp 3ph 208v to 30amp 1ph 110v. When I have shore powered other mv's in the past they were sorta grounded by Mil metal ladder going to ground. A couple of friends, one has a s280 on civi low boy trailer and when it is hooked to truck, jack leg up it knocked the crap out of his dog as he tried to get up on the dove tail, other guy is a MARS guy has a109 as a ham shack used a fiber glass ladder to get in and out and I leaned up against truck and got a jolt. My new shelter came with a high dollar mil ladder with rubber pads on the bottom and would like to keep it that way. Comments/advice? Thanks in advance
