New to the forum and I have a question . 3 speed trans
I have owned my truck for about 4 months with no issues. today I cranked her up and the truck hesitated while moving. it will go forward but wants to downshift at higher speeds. when I try reverse it moves an inch and then nothing .
Trans fluid level is normal and doesn't have a burnt smell. I pulled the little side cover off on drivers side of radiator shroud and the trans cooler line was really hot.
any vacuum lines?
Transmission toast?
Thank you
any vacuum lines?
Transmission toast?
Thank you
