BrooklynnMasonry
- 0
- 1
- Enumclaw Wa
Hey all, this is my first time posting to the forum. With that said my M1078 just arrived on the truck, just to find out it won’t start. The driver drove it on the truck and was letting it idle to charge the batteries and it had a check trans light on the dash. It’s sorta fuzzy from there he said it died and wouldn’t start. I figured probably the batteries were bad and maybe not enough power to the circuits so I bought 4 group 31s the day before it was delivered. Anyway we ended up installing them to try and get it started with no luck. I was thinking back to the driver mentioning a trans light on and the truck dying. I then noticed the Allison keypad not lighting up saying it’s in neutral. After what seemed like hours one of my neighbors came over that’s a diesel mechanic for a near by fire department and pulled some relays out and was able to apply power to the neutral start relay. Bam like a bolt of lighting it fired right up! Still no selector visible on the Allison key pad.... no forward or reverse. My neighbor pulled it off the trailer with his backhoe now that we had breaks now it sits hoping someone here has had the same problem as I! Can you guys guide me in the right direction!! Thanks Bryan.
