Try to weld in or patch over
ramdough
1,729
Austin, Texas
I have a 6 spots (3 shown in the picture) that I need to patch.
No one will probably ever see it. Should I try to weld it in (I am not the best at thin metal), or patch over with a small plate and body caulk?
this Is not a show truck.
Thanks!
INFChief
1,348
New York
Thanks!
Tap them flat then tack weld a small piece of filler. That, or simply put a patch over the whole thing - rivet in place.
MarkM
CODE BROWN...It's all going to sh~t !
1,968
WOBURN. MA.
If possible weld it. If welding is no good then I would go with Gorilla hair filler as it bridges gaps well and resists cracking. Easy fix.
Mark
Karl kostman
889
Fargo ND
Ramdough if it were mine and because they are pretty ugly looking, looked like bolts that pulled through? I would pound them flat with hammer on both sides and cut steel patches and weld them in place then grind them flat and coat the patches with a light coat of bondo then sand and paint. My feeling is if your going to put the effort into it then do it correctly, only my opinion.
Captaincarrier
241
St Pete, FL
X2
I use clear plastic wrap (from the kitchen drawer) outline the problem area and cut my fill pieces. Tack weld, flair it in, sand it out.
