kapnklug
- 2
- 18
- spencer,ny
Installing a GM-3 turbo on my '86 M1009 using salvaged parts from a 93 K3500 6.5 TD. Problem is, there are no ports on the intake or exhaust manifolds at all for installing the boost and pyrometer senders. I don't mind drilling and tapping the aluminum intake, but i'm not gonna drill and tap that cast iron exhaust manifold. I'm thinking of mounting the pyrometer in the crossover pipe close to the driver's exhaust manifold, by welding on a double-female pipe fitting over a hole drilled into the pipe. Anyone else encounter this problem?
