Turbo NHC-250
jwj438
Michigan
Hope I’m not beating a dead horse but picked up a 5 ton and it came with all the parts to turbo it. I’m looking for info in if what I have will actually work. I know some guys say don’t do it. Others say you can’t polish a terd. My take is, the parts came with it. If it won’t hurt it. Why not have something unique.
So, I have a 1970 NHC-250 in great shape and have a HE551V turbo with the liquid cooled intake manifold and two turbo exhaust manifolds. My first question is can The is turbo be used with just a boost controled actuator on the variable geometry control. Will this hurt the turbo or engine at low load?
If this won’t hurt anything I’m looking at running an air to air intercooler (selling the air to liquid manifold) and only running 1800rpm max. And max 1100 F. EGT And of course lots of pump tuning. If this would not hurt anything I think I can make lots more torque. I don’t care about HP
Thoughts?
Bobbeddeuceswild
Apex NC
So about 8 months ago I installed a turbo on my 813. Took a little while to dial in and play with intake and exhaust routing but I got it figured out.
I’m trying to figure out how you could use the vgt turbo and have it work good for you.
simp5782
Feo, Fuerte y Formal
9,513
Mason, TN
Just crimp the hose off with a zip tie. Would be better off with a cheap HT3B turbo or 4LHR. It's simple.
Bobbeddeuceswild
Apex NC
I’m using a small cam 290 intake manifold, a 855 pulse exhaust manifold, 4LHR turbo, 350hp injectors, 5 inch exhaust, and played with the injection timing a little. I can hit 20 lbs I’d boost all day long. Doesn’t smoke at all.
sandcobra164
323
Leesburg, GA
Adding a turbocharger to a non-turbocharged diesel is no big deal and you already have the correct manifold and turbo. You just need an oil supply and drain line. Once you sort that out you will be miles ahead. In my personal experience, my NHC-250 pulls the gears just fine even when towing a heavy load. Greatest to date is 26,000 pound towed load and I was still able to roll at 65 mph. It's gotten better since I installed a "dual fuel line" setup. Some people will tell you that you'll melt the engine once you install a turbo. As long as you don't touch the injection pump, no worries. If you do make adjustments to the injection pump, install a pre-turbo exhaust temperature gauge and keep it under 1,100 degrees.
