turbo oil return line
BFR
Rocket Surgeon
2,330
42
North Georgia
I am hemorrhaging oil from the return line on my turbo. Anyone know the specs of the hose? I tried having it matched locally and wasn't particularly successful.
JDToumanian
14
Phelan, CA
NAPA also has silicone hose.... Overkill perhaps but I know I'll never have to replace it. When I told them the hose was for a turbo oil drain line it's what they recommended to stand up to the heat, though I'm sure the regular hose will last for years.
Jon
WillWagner
2,638
Monrovia, Ca.
Emmado22 and jimk are correct. Jon, the silicone hose you put n WILL fail, very fast. The wrapped hose Bjorn used will be better. If you can find a Stratoflex orAeroquip braided hose, that will do nicely. I used a wrapped, high temp silicone hose from Cummins that is made for the turbo drain. It is a p/n 3818267. It is not inexpensive! But it will last longer than most of us will own the trucks.
JDToumanian
14
Phelan, CA
Why, Will? What makes your silicone hose better than mine? It's been on there for a year and a half. Surely oil will not dissolve the silicone, and there's no pressure or mechanical stress there... Explicar por favor.
