Can't change a small cam to a big cam. Big cam engine and small cam engine are two different animals. I guess you wouldn't necessarily have to do a fuel pump on it, if you don't mind alot of black smoke on accelereation! No timing changes. You can still put jakes on it, just use the rear 2 heads and leave the front off, Ford and Volvo have been doing that for years. Yes, you will only have 2/3 the braking power, but that is way bettter than using a potato brake. Ya know,there are two types of x-overs for a turboed, non aftercooled small cam, one is a steel pipe that makes a big sweeping bend into the intake and the other is aluminum that makes close to the same bend. The x-over for a big cam is flat, made of steel or aluminum and clears jakes if installed. You could make a plate to neck down the big hole in the intake for the small cam x-over and use the big cam x-over. BTW, if you add a turbo, use the Holset, not the T-46 or ST50
