aboonski
- 8
- 18
- West Melbourne Florida
I just received a used take-off 'C' turbo today and it looks as though it was taken off for a good reason! There's a lot of play in the shaft - I just went through the compressor side with my finger and found this out. I just want to know if there is a place that I can send this unit to and have it rebuilt or have the bearing replaced. The fins do turn freely and I cannot see any other defects thus far. It would be interesting to know how much acceptable play is normal in a 'C' or 'D' turbo - also, if the parts are interchangeable such as the guts of the unit from the 'C' to the 'D' or visa versa. Once I have replaced the 'D' with the 'C' turbo, are there any adjustments that have to be made with the fuel injector pump or the viscosity compensator system? Seems like more air would be forced into the combustion chambers with the 'C' turbo which would probably require a richer mixture of fuel - am I right? I'll bet Kenny Knows! Thanks for any advice at this point. I will not put this other turbo on until I know the skinny on everything. Also, White Owl supplied me with the new turbo gaskets - $18.00 for everything. I am very anxious to install the 'C' turbo on my deuce because all that is missing right now is the sound! Al Broadbent
