Turn signal control plug rebuild?
18operator
1,861
Seville, Ohio
C51440A7-E985-4F32-9458-5BBBED73CE28.jpeg0088562B-4A6F-47E2-A2C6-9FB536B88656.jpegHey all. I found the wires going into the female end of the turn signal control plug were frayed. Is it possible to rebuild the female end of the plug? The controller still works. I just don’t like having exposed wires. Before I damage the plug, I figured I’d pose the question. 18BC35F5-61B0-4727-83EF-B6E938F3A2C2.jpeg
Guyfang
27,308
Burgkunstadt, Germany
You should be able to take the plug apart. The pins can be removed. If the wire is just soldered in the pin, you can replace it. If its crimped, well, there are ways to fix it, but most are crappy ways. We did it, because there was no way to get just the plug, back in 1970's. Later we had repair kits, pins and plugs. Clean it up and then stick it back into the turn signal. Dont screw it it, just stick it in. Take a wrench and turn the plug head off.
