Hi, I was wondering if anyone has found a solution to the aging turn signal stalk. My new to me M1088 wipers went up and got stuck in the up position and jitters back and forth a little bit but won’t go back down even with manual help pulling the wipers down. I’ve read that the stalk is often a culprit. It’s quite sticky and difficult to switch on so I think there might be some dirt causing plastic wear in addition to the contacts needing cleaning. I’ve also read that there are a lot of little parts and taking it apart can be time consuming compared to land cruiser stalks I’ve rebuilt before. A used stalk seems to run 500-700 which seems outrageous for something likely to fail when a new stalk for a big rig can run $50-80 and would be more reliable.
