Turning up the fuel....again!
cranetruck
75
Meadows of Dan, Virginia
Is this what you are looking for?
1) Loosen the lock nut
2) Turn the adjusting nut clockwise (as you are facing it) to make the screw move out. This increases the fuel delivery. Try one turn for starters.
3) Tighten lock nut
The screw doesn't have to move a lot to make a difference in delivery.
As usual, it's highly recommended that you watch the EGT and boost after this procedure.
marksgarage2
Southampton, NJ
Thats it Bjorn. Thanks. Didn't have time to drill for the pyrometer when I had the turbo off. Had to get the truck back running. We have 2 trucks up stuck here since last weekend and another deuce last night. I will pull the turbo and drill when I can.
