Type of brake fluid in M715?
rumplecat
221
North West Arkansas
RE: Brake
Mike:
I would suck out some and do the water test on it, it could be dot 5! You don't want to mix them!!!
James G.
maddawg308
762
Appomattox, VA
RE: Brake
Well, I am in the process of replacing the entire brake system, lines, wheel cylinders, master cylinder, EVERYTHING. So, I'll have a fresh, uncontaminated system. Since there will be NO brake fluid in the system, and never has had any put in it previously, would you all recommend DOT 5? If so, why?
rumplecat
221
North West Arkansas
RE: Brake
Mike:
I don't know of any advantage Dot 5 has over Dot 3 except it doesn't absorbe water, Dot 5 is also about 5-6 times more expensive! Did you stay with the original mc?
James G.
papercu
31
Baxley, Ga.
Fluid
It depends on how you drive your truck. The military went with the DOT 5 because at the time most of the vehicles didn't see a lot of use and any water in the system was trapped.
If you drive your truck regular go with DOT 3. Wayne
