Type of hose for remote reservoir?
yolner
68
Rockville, MD
I'm planning my remote res and need info on what types of hose are safe to use with BFS and pressure of 15psi (for the bleeder). I'm planning to install a ball valve so I can isolate the reservoir from the rest of the system and then plug in my pressure bleeder to pressurize.
I tried posting in the remote reservoir thread, but I guess nobody reads the last pages of a giant thread like that.
1,174
Maybe you just need to wait for someone to post to your question. Asking the same thing in multiple threads is against the rules. It's called cross-posting. It wastes peoples time and is rude. So is bumping a thread that is not time sensitive.
You could also read the other remote reservoir threads. Easily found with a search
harleyrkc
Burton, MI
I just ordered my resevoir parts but I'm holding off on the hose. I'm hoping to locate an adapter fitting to go from the barb to male pipe thread. I know the fitting exists because they use them to connect the two sides of Harely Davidson gas tanks. And that would allow me to run the line in steel or copper.
yolner
68
Rockville, MD
I waited 3 days. I think that's reasonable. I haven't been able to find any specifics on the types of hose people are using in any of the threads.
yolner
68
Rockville, MD
Mcmaster has what you're looking for. I don't have the part number in front of me, but I found a 1/8" NPT to 3/8" hose barb fitting there and lots of other possible options like compression fittings for copper tubing.
I'm also going to order the hose from there when I figure out which kind to get.
1,807
I've used the clear vinyl hose before with good results. Use the same stuff on my power bleeder as well.
yolner
68
Rockville, MD
I'm going to go with vinyl braided. Looks like it's rated for more than enough pressure/temp and is cheap at HD. I'll cover it with some air hose I have around just to make sure it doesn't rub through on anything under the truck.
chicklin
Kansas City, MO
I just used normal clear vinyl tubing from the hardware store. Running DOT 5 and no issues so far. Was able to pressurize it to 10-15 psi without problem.
Heavysteven
10
Hickory Flat Ga
Is silicone brake fuild even corrosive? From what i understand it does not react with the steel brake lines.
Better question what type of material are the brake lines made of? The soft hose ones
