u bolt delema
turfything
acton/ca
I'm just wondering if any one has the part # or can give me some direction on where I can get u bolts for my M1028. I have 4" Rough Country lift and the u bolts only fit the 1/2 and 3/4 ton trucks. I called Rough Country and the dude on the other end seemed lost. The u bolts need to be around 15" long. Any help would be appreciated.
saddamsnightmare
80
Abilene, Texas
March 8th, 2010.
:ditto:on the spring shop. Most can make anys size you need, and it is not recommended to reapply the old U bolts ever, as they have already taken their first and only set when originally applied.
Cheers,
Kyle F. McGrogan[thumbzup]
puppy
Rives, TN
Rear u-bolts I assume?
The kit "should" have included the correct u-bolts for a 3/4 ton, but in the case of a CUCV, you will have to do the rear u-bolt "flip" which requires a new rear spring plate.
skateabrock
anchorage, alaska
why would you have to flip the ''u'' bolts? you can have any spring shop make them square or round.
scottodog
nj
Just had a set made for my m1008 5/8 by 2 1/2 by 14 at a local spring shop square to fit stock axle. Took them 15 min and cost 65.00 for four.
4bogginchevys
rathdrum idaho
I agree that flipping the u-bolts to point up is a good idea if that is what you meant. Always thought it was a bad idea to put the threads down for dirt rocks and muck to mess them up. I've seen newer trucks with them bent so bad they'll have to be torched off. At the local store where I buy all my u-bolts they dont even sell the square ones for the 14 bolt 2WD (usually pointed down) because everyone points them up out of harms way....something to think about2cents
turfything
acton/ca
I think I will try the spring shop thing. I kinda want to keep the extra overload spring, just in case. I'm in the process of doing almost a frame off restoration. Thanks for all the advise.
Alucard-HD
PA
I had a 1 ton before and i ordered the U bolts front and rear from national tire and wheel or desert rat. and they worked perfect. as far as spring plates go i just found some in a junk yard and FF 14 bolts are easy to come by.
turfything
acton/ca
My new U bolts are here. My M1028 should have a nice stance in the near future. I ordered them online. $65 delivered. If anyone wants the link I can post it.
