u-Bolts
Rebelpride
Thomasville, NC
I plan to lift my M1008, but I didnt buy a kit I came out cheaper buying it seperate. Question is do I reuse my stock front spring u-bolts or do I buy new ones if so where.
grounded
Banned
928
defiance oh
buy new ones. always better off.
you can get a set of new U-bolts made up for about $40-60 (each axle) just hit up your local big rig shop and they will make them there on the spot for ya. Just let them know what you need. Width, length, round top or square top, and thickness and they will get ya squared away
AJMBLAZER
Paducah, KY
I had to have a local autoparts place that specialized in heavier stuff make me a u bolt for the front. The two on the driver's side were no problem, NAPA had those. The one on the passenger side was a PITA as no one had the right width. After a lot of searching I found the guys that made me one. Their price wasn't bad at all.
Croatan_Kid
New Bern, NC
I can get brand new front u-bolt sets from Superlift for 47 bucks all day long :-D
They're 5/8ths diamter, even the stock ones. Plus, when you but new ones they come with new studs for the diff housing too. You pretty much have to use new ones anyway, the stock leafs packs only have two leaves, aftermarket ones are 4 or 5 usually, much thicker.
Elwenil
40
Covington, VA
Always replace leaf spring U-bolts. They stretch to fit and can fail if reused. The nuts are one use only also. NAPA carries a good selection but I have run into a few that I couldn't find. For the oddball large one for my front D60 I went to these guys and they got me fixed up very well:
http://www.stengelbros.com/
Westech
CPL
6,104
207
cow farts, Wisconsin
for the 10 bolt is 5/8 inch thick x 3 inch curve x 7.5 inch long (that's 3 of them) and the 5/8 thick X 3.5 inch curve and 9 inch long. That's for stock. if you have thicker springs or add a leafs you will want longer ones.
aboonski
West Melbourne Florida
I want to lift my M1008 too so that I can use my H1 rims and tires on the truck. Lots of work in the process besides lift blocks and U-bolts I hear; longer brakes lines and a special Pitman arm is required. I just wonder about the cost of the lift just in the parts alone and possibly a link to previous posts about the subject. The stock wheels and tires are just worthless when it comes to sand and expecially mud like I was exposed to during an outing in Suburban Estates, Holopaw Florida! I even uploaded a few videos of this very popular off-road area that is open to "land owners only". My friend Lavarok (Ian) had to rescue me from the mud and this would not have been the case with wider and taller tires!
Elwenil
40
Covington, VA
Don't forget that you are going to need spacers to run the HMMWV rims. You are also going to have to swap to 8 lug axles or use a spacer/adaptor.
AJMBLAZER
Paducah, KY
westech, the OP is talking about a M1008. No 10 bolts there.
Elwenil, aboonski is talking about on his M1008. 8 lug axles. You are correct about the backspacing issues though.
