RE: Re: RE: U joint lubrication secrets???
Smitty is correct...
To quote from the Spicer manual:
"Spicer replacement universal joint kits contain only enough grease to provide needle bearing protection during storage. It is therefore necessary to completely lubricate each journal cross and bearing assembly prior to assembly into the driveshaft yokes. Each journal cross lube reservoir should be fully packed with a grease. Each bearing assembly should also be wiped with the same grease, filling all the cavities between the rollers and applying a liberal grease coating on the bottom of each bearing cap. After the kits are installed into the driveshaft yokes and prior to placing into service, relube as follows:
1. Using the proper lubricant, purge all four bearing seals of each U-joint. This flushes abrasive contaminants from each bearing and assures all four bearings are filled properly. Pop the seals. Spicer seals are made to be popped."
The manual then goes on to explain how to grease them if the seals don't pop (which would help sailor2000 out, but is too long to post here--follow the link below)...
For more info on the care of u-joints, see:
http://www2.dana.com/pdf/3306-6.PDF
Spicer (Dana) has a lot of good tech info online, you just have to go to thier website and poke around in the "literature" section or do a search...
In the same bulletin, they remind you to lube the slip joint at the same time that you lube the u-joints:
"Relube slip assemblies at the same intervals as universal joint kits. Apply grease gun pressure until grease appears at the pressure relief hole in the slip yoke plug. Cover the hole in the plug with your finger and continue pressure until grease appears at the slip yoke seal."
How many of you cover the relief hole and keep pumping in grease until it comes out at the slip seal???
Good luck.
