U-joint phasing
jodka
Bloomington, Indiana
The caption says "Earth borer drive shaft and universal joints." Is it is ok to rotate an earth borer at non-constant speed? If so, then then the phasing as pictured would be correct.
- Allen
cranetruck
75
Meadows of Dan, Virginia
I suspect that if little or no flexing is involved, the phasing is less important.
The drive shaft on the xm757 from the transmission to the transfer case is phased incorrectly and must have been so for years.
A formula showing vibrations as a function of the angle can probably easily be found.
cranetruck
75
Thanks Matt.
It's kind of like building a house and living in it before it's finished....you get used to the unfinished parts and the house never gets finished.
I'm trying not to jump ahead and start driving the thing before it's finished, so I keep it on blocks...he he he.
SierraHotel
Haymarket, Virginia
I will have to check this weekend, but as I recall, the ends of the U-joints between the transmission and transfer case are slightly rectangular, making it so that you cannot get them out of phase. Kind of threw me at first because they look square. I never considered phasing. Thanks Bjorn..!
jodka
With reference to the above plot: it still seems that while pulsing the drive wheels through an incorrectly phased ujoint pair would vibrate the entire truck, pulsing an earth borer through an "incorrectly" phased ujoint pair might be harmless, and thus any phasing for that particular application would not in fact be incorrect.
- Allen
rizzo
Port Huron, MI
I had to take the inter axle shaft apart on my M108 and the splines have one larger spline so that it can only be put together the one way
FSBruva
Marietta, GA
rizzo-
Is it the correct way? Just curious how widespread the military's "phasing" issues extend - saw three pictures in a 5-ton parts manual that demonstrated incorrect phasing. I think it was the -34P?
Matt
