U Joint
Superdave
12
Onoway Alberta Canada
Does anyone know where I can locate a U joint for my center axle shaft as mine needs replacing ?? I did a search on the Gamma Goat site and I found no answers there and I contacted Rive-Rad and the did not have any :(
Gamagoat1
Kiowa, Colorado
Which center axel shaft u-joint??
Transmission/Transfer: joint type - 929 (Mil. Spec. 2520-00- 086-1940)
Rear differential: joint type - 929 (Mil. Spec. 2520- 00-086-1940)
Tractor/Carrier: joint type - 929 (Mil. Spec. 2520- 00-086-1940)
Center differential joint type - 565 (side shaft), (Mil. Spec. 2520-00-781-7806)
Under Engine: joint type - 933 (Mil. Spec. TBD) All available at NAPA or the like.
Anything else , just take the old one in and match it...............
Superdave
12
They are the same on both ends of the AXLE shaft ( the shaft from the diff to the wheel).
Gamagoat1
Kiowa, Colorado
Yes, both ends are the same on a front and rear axle shaft. (8 of them) Also the same on the center. (4 of them) just larger.
m1010plowboy
2,515
Edmonton, Canada
Gama Goat U-joint
Dave, real hard on things aren't you! Probably one of the coolest tours of the swamp I've ever been on. ahhhh the Goat. I'll help any way I can.
I'm guessing one will show up.........real soon.....if you don't have it already. Any chance one could be fabricated if we're out of options??
I saw a bunch of scrapped goats online......What about some recycled parts?
***You've probably already been here but I'll drop the link anyway.
gamagoat
*** Another shot in the dark and out of the box thought but maybe....extra parts sit in a museum somewhere. New York? Charlotte Carolina?
Carolinas Aviation Museum - They have a goat .......Fully restored and in running condition - currently in storage.
I'll keep diggin
Militoy
Mojave Desert, CA
It looks to me like the center drive axle shaft assembly (11640263 NSN 2520-00-781-7818 ) is unique to the Goat. You might have some luck bringing the shaft assy into a good heavy truck parts dealer, and letting them have a go at matching the U-joints. Otherwise - look online for someone parting out a Goat. There are several on eBay that eternally list Gama Goat parts for way more than they are worth (unless that's the only place you can find parts!):oops:.
Superdave
12
I got a couple U joints from Capital Gear a local DriveTrain specialist and the part numbers off the bill are as follows.
TGD 5025R U-Joint, 2-6R, 2-6C Caps. They were $158.00 EA.
This is for the Center axle ( Inner and Outer ) as the front and rear are different.
Hope this helps.
Gamagoat1
Kiowa, Colorado
All eight U joints for the front and rear drive axles are the same. The center or tractor rear (All Four) are much larger..
Glad you found them Dave..
What brand were the joints you found??
Gamagoat1
Kiowa, Colorado
2 u joints for each axle, that's 12 total.
7 u joints on the main drive shaft.
6 u-joints are for the steering shaft.
Don't forget the 2 torus bearings on each end of the center differential and the 2 Torsilastic bearings on the carrier articulation joint and the carrier bearing on the rear drive shaft.
Fun!!!
Superdave
12
$158 EACH? :shock:
That adds up quick on something with 30+ joints.
The center or the main drive axles in 2 wheel drive are quite large in size (requires 4 in total) but I was also in shock when he told me the price. I tried a couple of the surplus dealers with no luck so you some times have to bite the bullet with oddball style parts that are not the norm.
Brian Mann
Sicklerville, NJ
more confussion over U Joint NSN numbers
Just found some U Joints wrapped in grease paper, sealed in cardboard boxes and inside a plastic bag. The NSN on the box is on the government label 2520-00-086=1940. They have bolt caps on all four joints and are not going to work on my M561's wheel axles. AQre these for the drive train between the differentials and transfer case? Does anyone know for sure what the NSN is for the joints that run from the differentials to the wheels?
Emmett
Tampa FL
Greasing U-jointsas we know is very important. If you don't see grease comming out of each end of the U-joint, you might want to take it out and insure that grease is getting there.
Ask me how I know this....grrrr.
Superdave
12
Those u joints are for most of the propeller/ drive shafts with 2520-00-086-1967 being the other u joint that is listed for them.
Jericho
69
Landaff NH
Ask and you shall receive , Was looking for the P,n for the u joints and found them here, super thanks Super Dave, will try the numbers at the local NAPA tomorrow, Andy
