admiralking
- 1
- 0
- Las Vegas, NV
Elwenil,Keep in mind that your truck is full time 4WD. It is not going to make sharp turns as smoothly as a part time 4WD truck would. If you have a limited slip differential in the rear axle, it can also grab causing a vibration on sharp turns, especially if limited slip additive was not put in the axle when the gear oil was last changed.
I'm going to assume you know your truck is not an actual M880 series as it's a '79 model and M880s were only made in '76 and '77.
Lanty is correct, the M880 series were 76 & 77 model years only. An M880 would have M880 & 1 1/4 ton in the NOMENCLATURE line of the data tag.Elwenil,
Thanks for the info. Here is the placard on the dash:
I did assume it was an M880... Am I wrong?
Are you sure your gear is in Hi and not in Hi Lock..My '79 Dodge M880 has a distinct wobble when I make a u-turn, even at slow speeds. I have 75R16's on it with the standard suspension. Has anyone ever encountered this issue? Any suggestions for a fix?
