Undercoat-stoneguard
red devils dude
Ft Campbell
I want to undercoat the deuce with something a little harder then auto part store
"rubberized undercoat" something harder and less likely to pick up rocks would be nice :grd: :lost:
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
I have been impressed with the Herculiner on my 725. If your getting under the truck to put it on, make sure you are well protected. A gallon is usually 100.00 or so, Pepboys has a 20.00 mail in rebate if one is near you.
gimpyrobb
27,786
755
Cincy Ohio
Well it cost less to do it once. I hope that doesn't come off as offensive. I went cheap as dirt once and got bit.
maddawg308
762
Appomattox, VA
Re: RE: Undercoat-stoneguard
red devils dude said:
anything pricey is out cost of paint's killing me.
Just remember Jed, you get what you pay for. The cab bottom is torture tested every ime you run your rig in wet weather, wintertime (with the salt on the roads), even when it's parked in humid weather the moist air get stagnant under the body of most rigs and accelerates the rust. Normal paint or underbody coating won't do any better than what you already are doing with the $5 a spray can undercoat stuff. If you need better protection, it's gonna cost you.
red devils dude
Ft Campbell
I all most never take any thing as "offensive" I'm just running out of money for the paint I'm
going to call the ziebart place see what they can do.
bigmike
354
Dixon CA.
RE: Re: RE: Undercoat-stoneguard
I'd go with roll-on bedliner. Walmart has bedliner for cheap per gallon. I am also looking at durabak and grizzly grip for colored bedliner to use in my cab and wheel wells.
