April 13th, 2010.
Aximony:
If you were in North East Texas I would be pleased to take you for a ride in the S404.114. Not a lot of speed, not much in brute power, but rarely ever stuck, and it rides and handles good. The only problem my S404.114 has given me is from bad gasoline, a common problem down here as they don't clean the station tanks correctly. If I had the money I would hunt down a very good used U1300L diesel, with Ultra High Speed Axles, usually found on a fire truck or ambulance chassis, as they can cruise 70 MPH all day long, and the U1300L's are generally diesels.
Bear in mind that the stock S404.114 (about equivalent in design to a Model AA truck (Ford), has final gearing in the axles of 7.65 to 1, and the stock transmission is 6 gears ( 1 & 2 low range forward & reverse) 3,4,5 & 6 are the road gears and FWD gears.
The transfer is set up: 2WD, 4WD, 4WD-Locked mechanically so all 4 wheels have to slip together. The transfer case is sufficiently sophisticated that it will shift into and out of 2wd, 4WD, 4WD-Locked without the clutch if the truck is not slipping, if it is the clutch must be used to get the truck to go into or out of gear. No slipping, no clutch needed for any shifts in the transfer case!!! There is an add on auxilliary transmission for 1 &2 gear that will give the truck 8 gears in low range and L/L will cover about 450' per hour! They also have the ability to take front, rear, left and right PTO connections, and the U1300L's have or can be adapted to drive a diverse set of hydraulic implements, like our SEE's do.
My Unimog prefers to cruise about 40-42 MPH (approximately 60KM/PH), due to the brass bearings in the transmission, they hate going much faster for any length of time, but it could in a dire emergency hit 56-60 MPH very briefly. Personally, I would hate to get rid or either truck, as both have their merits, but most guys that have had Swiss S404.114's in good shape and have sold them almost always regret the fact later....
Mog 1300L up above seems like he would give you a ride in a U1300L, once you have tried one, nothing else will do, asl Mike Pop on here about the one he had.....
I might end up posted at Edison National Historic Site in West Orange, N.J. depending on how my job search with the Federal Government goes, so you may get to see a S404.114 and an M35A2 in the neighborhood..... ( or with my luck, I might not get employed at all and have to sell all the toys and the house....!).
Cheers,
Kyle F. McGrogan
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
