Unimog SEE FLU-419 Winch question
Another Ahab
4,352
Alexandria, VA
Sorry. Can't help you there.
Not a Unimog answer-man; I just like them is all. But somebody'll know.
Is that rig of yours parked on a wooden deck? Little unusual. You got a plank driveway?
UNIMOG-GUY
25
Blacksburg, VA/Denver, CO
No the Unimog pictured isn't mine or my friends so I don't know what it is parked on. It was a picture I found online and he wants a winch like the one pictured for the front of his SEE FLU-419.
zebedee
conceptualizer at large
700
Central NY
It looks like a factory add on - as in Mercedes not Freightliner.
I remember in the UK, friends who had 404's used to call it a rubbish bin (UK) winch - 'cause it looked the same size as a 'trash can' (US) mounted on the front bumper.
Not a huge capacity - I think the cable is in the order of 9mm...... But I'd stand corrected from the more informed.
UNIMOG-GUY
25
These people should be able to answer your questions;
http://www.unimogs.co.uk/gallery/gallery4.asp?category=10&start=1
I wish they did... Here is my correspondence with them:
Simon,
I am wondering if you could tell me what manufacturer/model winch is in the picture on the front of the SEE FLU-419? Do you have any for sale? If not do you know where I could source one?
Thank you in advance,
Chris
Chris,
I’m not sure who made the winch – it isn’t a type which we’re familiar with I’m afraid.
We have nothing similar currently available.
Kind Regards
Simon
+44 (0) 15242 62922
Wenning Mill | Wenning Ave | High Bentham | Lancaster | LA2 7LW | United Kingdom
www.unimogs.co.uk
www.tpwoodchippers.co.uk
www.agricultural-tyres.com
Registered in England | Company Number: 2873238
Another Ahab
4,352
Alexandria, VA
That's a drag, hitting a total dead-end like that.
Have you tried Mercedes directly? Maybe they have a "tech questions" department that at least might steer you in a likely direction.
tennmogger
541
Greenback, TN
That winch does not look stock to me. The mount for the winch, how it connects and bolts to the work plate/accessory horns, does look Unimog-ish. But looking closely the winch is connected to the mount by smallish bolts in tension (not even in shear, straight tension), definitely not the MB Unimog way. No serious manufacturer mounts winches that way. I think this is a fabrication, one of a kind probably.
peakbagger
359
northern nh
That photo pops up on this thread on another forum on FLU 419 implements https://www.benzworld.org/threads/never-say-never-with-unimog-implement-mount.2465177/
My guess is its one off mount for the military. Some one with the right fab gear can make up the plate that mounts to the military specific mount and go from there. The adaptor plate looks like a factory cut (smooth ) so it may be from a loader but looking at the rest of the fabrication I see some torch cut pieces. On occasion I see military surplus hydraulic winches of various sizes so expect someone with fab experience could just make one and paint it green,.
That snowplow on the other thread is what I would love to run into ;)
tennmogger
541
Greenback, TN
Great update! The picture from the older thread, and from this thread, are of the same truck, same winch so could still be one of a kind. The new photo does show a much more robust lower mount for the winch assembly than I thought. There are two heavier bolts on each side, in shear (not tension), and in line with the pull of the cable.
That's a nicely modified SEE, to non-SEE status.
1967corvette
wayside new jersey
Not a fabrication
