Will be doing an overhaul on the Sherman tank turret traversing system this winter, and the manual for the Oilgear system specifies the use of "Oil, Hydraulic, Univis 47". Anyone know what the spec is for this Univis 47, and the name of a modern equivalent? I will need about 1 gallon.
Thanks for any assistance/direction.
PS. Says I can use SAE 20, but only in emergency, and must remove it at earliest opportunity, and replace with proper oil, so no point in going with SAE 20.
