- 2,914
- 9,582
- 113
- Alexandria, La
OK all-
I had a situation last week where my "unloader valve" got stuck in open(?) position and I had to whack my air compressor with a hammer to close(?) it. For those who don't know, it's located under the injection pump on the driver's side of the engine.
Here are my questions:
1. What is the "proper" term for it? I have been looking through the -10 TM, but as I'm not exactly sure what function it does (all I know is if it gets stuck you lose all air pressure and cannot build more), I cannot rely on descriptions to find it.
2. Once I find the correct name, is there a procedure to rebuild or clean this valve? I will not be opening it and lubricating because lube and contaminats=glue, and I'm only kicking the can down the road to deal with it later.
3. If there is a rebuild procedure, are there kits available for purchase?
I appreciate all information and help.
