- 141
- 145
- 43
- Parsons, TN.
Several years ago I had a friend that was in the logging business. He had one truck that I had never seen before, or since. It was at least a 5 ton, 6x6, with a detachable bed. The only data plate I can remember was one that indicated it was a "dust control unit". I could not remember any model number. My friend said that it used to have a tank on the back, it was removed and replaced with a fifth wheel hitch. He used as a "pull out " truck, pulling loaded log trailers out to the hard road where a road tractor can hook to them.
The detachable bed I mentioned before was actually one half of the truck. You unhook the bed and the drive shaft running to the rear axles. Right behind the cab was a pair of wheels that could be lowered so that the front half could be driven without the rear half. The wheels were not powered, they supported weight only. Has anyone ever heard of such a truck or something like it? I'd like to see a picture of one in good shape. After years of work in the woods his was pretty ragged out. Thanks in advance!
