UOC for non ECV Turbo?
Mogman
9,696
Papalote, TX
If I understand correctly ( I am sure I will be corrected if I am wrong) that there were non ECV turbo trucks, as to say without the extended nose.
If so can someone give me the UOC code for that truck? it would be helpful when researching what components I might need for the up coming M998 A0/6.5L turbo conversion, for example the air intake ducting, I have the turbo air horn but am unclear on what I will need different if anything to get to the air box.
Action
1,559
East Tennessee
The UOC for non-ECV turbo is “H1”.
to connect the air horn to turbo is a blue / pink hose.
to connect the air horn to the air filter can, look for the rubber piece that had the reinforcement ribs on it. I am surprising how many flippers i see that use the old flimsy hose. Heck, i saw one last week for around $50,000 that didnt have any clamps on the air filter can. I bet that will rattle around!
And, when putting in a turbo, you may want to get the 1/2” thick spacers for each of the 6 body mounts. They go between the body and upper rubber mount.
Retiredwarhorses
4,207
Brentwood, Calif
All turbo trucks are ECV…
