minnhawk
- 2
- 3
- Mille Lacs, Minnesota
I have a 1953 M43. I would like to put a bigger engine and disc brakes in it for long-distrance highway driving. I have a donor 2006 GMC 2500 stretch cab pickup w/ 6.0 vortec& 4L80E auto trans.
I have completed the restoration on the M43 & repainted with crosses and correct numbers, etc.
1. Should I start by swapping the engine and transmission in? 6.0 swaps appear to fit (Petersen's 4 Wheel Drive , March 1, by Fred Williams "1965 Dodge M37 The Dumpster: Part one) and youtube author "Itchy Old Fart"
2. I would also like to swap the M43 rear end with the corporate 14 bolt GMC rear end with rear disc brakes. I would also use the master cylinder power brake set up from the GMC. (see previous cites)
3. I would also like to put disc brakes and power steering kits on the front axle.
OR
Should I measure up the GMC frame against the M43 frame and do a complete frame/powertrain/axle swap? I believe the GMC frame would have to be shortened. Someone mentioned that alternative on an old post on the G741 forum.
The more I ponder it, the more sense it makes to just swap the frames out. Either way, it is a lot of work, but the frame swap would actually be less expensive because I wouldn't have to buy brake and steering kits, engine mounts, re-perching the rear axle and so on.
WHAT DO YOU THINK? I need advice for my winter project.
OR
